Wires In Foam Sheet Insulation? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 10:46 PM   #1
Rewards Points: 502
wires in foam sheet insulation?
I was planning to insulate my ceiling with a sheet of 1" foam, then cover with drywall. Is there any reason I couldn't just scratch a "ditch" for a ceiling light wire into it?
forresth is offline   Reply With Quote
Old 11-09-2011, 12:28 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
Yes. Code requires the wire to be at least 1 1/4" from the face of the framing. If you decided to do this you would need to cover your "ditch" with 16ga steel.
iminaquagmire is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attic Foam Board Insulation JasonCA Roofing/Siding 3 10-07-2010 12:56 AM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
HVAC ducting and foam insulation seadrift HVAC 1 08-17-2009 12:11 PM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 12:41 AM
