Wires Bunched Together - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 08:20 AM   #1
gkaro's Avatar
wires bunched together
All,
A question about running wires together. Our local code states that if running more than a 2ft together.... the max no of 14,2s can be three.
Why? My thoughts are that if the proper wiring is used for a load, there should not be heat build up...why the restriction? Something about voltage drop?
gkaro is offline   Reply With Quote
Old 04-03-2011, 08:39 AM   #2
Electrical Supplier
Rewards Points: 150
youll have heat buildup regardless to some degree, (heres some basic physics)
copper has resistance and resistance creates heat with regard to current flowing through it.......
FURTHERMORE, if temperature increases in conductors (because they are bundled), the resistance increases, therefore reducing the maximum safe current......
As far as heat transfer/dissipation, CONDUCTION is more efficient means of heat xfer than conduction, if you have those wires together they will xfer more heat to each other than to the air....
Romex is rated for 60 degrees celcius, anything over that is unsafe and you must derate the wire......now service entrance is rated 75c and THHN is rated 90c, you can put more current through THHN than through NMB/UF......look at the 310 NEC ampacity charts.
It has nothing to do with voltage drop.
Look into the NEC appendixes in relation to conduit fill.......same applies.....'
to my understanding you can run them close to each other (a few inches apart) just not inside the same arbor holes, under the same staples etc.......just not bundled....
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 04-03-2011, 08:51 AM   #3
the Musigician
DangerMouse's Avatar
OK, I'm confused..... as usual.....
DM
Old 04-03-2011, 09:43 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by gkaro View Post
All,
This has to be a local amendment. I would hope they have it in writing somewhere.
The NEC, although NOT expressly stated, limits the maximum number of #14, #12, or #10 cables bundled to four, or up nine current carrying conductors, before derating needs to be considered.
Old 04-03-2011, 09:44 AM   #5
Originally Posted by Powerup26 View Post
What about when I use stack its??? Thats 8wires max I have together. I smell a "mr.knowitall"
Cables run in Stack-its are NOT considered bundled due to the intentional spacing provided.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
