Old 12-21-2012, 05:14 PM   #1
Wires on bottom of joists.
I was under my house in the crawl space, there are electric lines (MN 12-2) that are just hanging from various things. I know this isn't right. These wire are for off peak electric heat; baseboard heat in each room of the house. Is it to code to use wire staples to fasten them to the bottom of the joists? OR is it required that I drill holes in the 2x8 joists and run the wires though them?
studhauler is offline   Reply With Quote
Old 12-21-2012, 05:28 PM   #2
There's no reason to run them through the joist.
Only time they would do something like that is in a full basement where there was going to be a ceiling installed.
Old 12-21-2012, 07:22 PM   #3
Licensed electrician
Newer editions of the electric code would require the cables to be run through bored holes or on running boards. Earlier editions allowed the cables to be stapled to the bottom of the framing in a crawlspace.
Old 12-21-2012, 07:42 PM   #4
Special User
You can drill holes in the middle third of a joist, but that would require disconnecting the wires and refeeding them. (Never notch joists or drill the top or bottom third, as that destroys the structural integrity.)
When you run parallel (with) the joists, don't staple to the bottom, staple to the side at least 1 1/4" from the top or bottom.
If you go perpendicular (across), sadly, you can't just staple NM to the bottom. It's called "clotheslining", and it's not allowed. The solution is the running boards Jim mentions, you just nail or screw up some 1x2, 1x3, or 2x2 "furring strips" (they're very inexpensive) to protect and support the cable.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-21-2012, 08:47 PM   #5
The wires are running mostly perpendicular to the joist. Some places they run at a 45 degree angel. How long ago could you staple MN wire to the bottom of a joist, or clothesline it? I think these were put in over 10 years ago. The wire is white in color not yellow like todays 12 ga.
Old 12-21-2012, 08:49 PM   #6
Electrical Contractor
You are good to go to staple to the bottom.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
studhauler (12-21-2012)
Sistering Joists and Adding a Beam Mikeman Building & Construction 6 09-30-2011 09:11 PM
Pro Advice: Repair or Replace Deck ledger board and joists? jdm001 General Discussion 12 09-05-2011 10:46 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 08:11 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
