Wiremold To Romex Transition - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2012, 02:58 PM   #1
Wiremold to Romex Transition
Hey All,
So I have a bedroom and a sunroom that share a common wall. The common wall is made of brick.
I'd like to tap into the bedroom outlet on the common wall as a power source for surface mount wiring in the sunroom.
All the Wiremold articles I have read have said you have to start the wire mold from an outlet already in the room. well as the room is all brick there isnt one.
Is it acceptable to bring a line from the bedroom outlet box use NM knockout clamps on this wiremold box to get things started?
http://www.homedepot.com/webapp/wcs/...N#.UKP3g8XR7No
Thanks everyone!
nhoc6131 is offline   Reply With Quote
Old 11-14-2012, 04:46 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Use this box.
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-14-2012, 04:57 PM   #3
Julius793's Avatar
Don't even bother using the back put it over an existing outlet, you will need long 6-32's
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 11-14-2012, 05:05 PM   #4
electures's Avatar
I think he wants to enter this box from behind with a cable from the receptacle in the bedroom then extend off with wiremold.
Old 11-14-2012, 05:09 PM   #5
Yes That is exactly what I want to do! Thanks alot!
Old 11-15-2012, 12:58 AM   #6
This just dawned on me, I will not have enough clearance to use a clamp with my current plan because of the brick. the current alignment allows a straight shot through the mortar from the bed room outlet to the new surface mount outlet
Id have bore a fairly large hole to be able to recess the clamp...
Any alternative ideas?
Old 11-15-2012, 08:00 AM   #7
electures's Avatar
Chisel out the hole and make enough room for the connector to recess in the hole. Be careful not to overdue it as the mounting holes are close to the connector.
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
romex in wiremold hammer Electrical 9 02-24-2008 12:45 PM
