-   -   Wiremold to Romex Transition (http://www.diychatroom.com/f18/wiremold-romex-transition-163334/)
nhoc6131 11-14-2012 01:58 PM
Hey All,
So I have a bedroom and a sunroom that share a common wall. The common wall is made of brick.
I'd like to tap into the bedroom outlet on the common wall as a power source for surface mount wiring in the sunroom.
All the Wiremold articles I have read have said you have to start the wire mold from an outlet already in the room. well as the room is all brick there isnt one.
Is it acceptable to bring a line from the bedroom outlet box use NM knockout clamps on this wiremold box to get things started?
http://www.homedepot.com/webapp/wcs/...N#.UKP3g8XR7No
Thanks everyone!
electures 11-14-2012 03:46 PM
Use this box.
http://www.homedepot.com/catalog/pro...811a50_300.jpg
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Julius793 11-14-2012 03:57 PM
Don't even bother using the back put it over an existing outlet, you will need long 6-32's
electures 11-14-2012 04:05 PM
I think he wants to enter this box from behind with a cable from the receptacle in the bedroom then extend off with wiremold.
nhoc6131 11-14-2012 04:09 PM
Yes That is exactly what I want to do! Thanks alot!
nhoc6131 11-14-2012 11:58 PM
This just dawned on me, I will not have enough clearance to use a clamp with my current plan because of the brick. the current alignment allows a straight shot through the mortar from the bed room outlet to the new surface mount outlet
Id have bore a fairly large hole to be able to recess the clamp...
Any alternative ideas?
electures 11-15-2012 07:00 AM
Chisel out the hole and make enough room for the connector to recess in the hole. Be careful not to overdue it as the mounting holes are close to the connector.
