Old 12-06-2009, 08:54 PM   #1
Wireless Switch
I would like to turn on and off my outside lights with a wireless switch (Transmitter and Switch).
The current switch is 70 feet away from the house in a separate garage
Load is 1000 Volt with 20 amp
Any idea's where to get this kind of switch ?
Any other options ?
indy is offline   Reply With Quote
Old 12-06-2009, 09:07 PM   #2
Wireless Switch
I've had trouble with wireless things not working. People have even had trouble with their wireless keys not working for their cars.
The problem is too many wireless "signals" in the air and this can "jam" wireless devices.
Also metal walls, siding, etc. can interfere with the signals.
With that said, I would suggest going to a local home improvement store and buying something there. Then if it did not work, you could easily return it.
Otherwise online... Following is a google.com search for "home automation" and all sorts of web sites selling all sorts of gadgets for this...
http://www.google.com/search?hl=en&s...=f&oq=&aqi=g10
Billy_Bob is offline   Reply With Quote
Old 12-06-2009, 09:23 PM   #3
Wireless Switch
1000V at 20A? You sure?
jerryh3 is offline   Reply With Quote
Old 12-06-2009, 09:27 PM   #4
IBEW Electrician
Wireless Switch
where are you getting 1000v at your house?
Scott3229 is offline   Reply With Quote
Old 12-07-2009, 09:06 AM   #5
Wireless Switch
There is 100 amp subpanel in the garage. This subpanel is not being used for anything else.
Old 12-07-2009, 09:11 AM   #6
Wireless Switch
Your original post states a load of 1000V at 20A. Assuming this is a mistake, and you are just referring to a normal outdoor light, there are wireless transmitters and receivers that can be wired to outside lights. I had a security motion light that could be controlled by a wireless transmitter. Any home center should carry these and they are simple to install.
Old 12-07-2009, 09:19 AM   #7
Xtreme DIY'r
Wireless Switch
Maybe load is 1000 watts ? Normal household voltage is 120v
If high output lights - sodium, mercury vapor (?) they could be 240v
So (4) 250w lights = 1000 watts ?
Unless you have football field/skating rink etc outside your house
Old 12-07-2009, 09:45 AM   #8
Wireless Switch
My mistake, it's 1000 Watts max load for all the lights
Old 12-07-2009, 03:46 PM   #9
A "Handy Husband"
rjniles's Avatar
Wireless Switch
Most of the wireless switch units I have seen are rated 500 watts maximum, incandescent only. If you are using sodium vapor or other non-incandescent, chose your product carefully. Also be aware of the maximum power that the unit can handle.
rjniles is offline   Reply With Quote
Old 12-07-2009, 06:10 PM   #10
Wireless Switch
if the lights you have are incandessent, go to www.x-10.com theyll have something to work for you. Ive had pretty good luck using their products in the past.
journeymanj is offline   Reply With Quote
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
