Wireless Remote For Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 02:15 PM   #1
wireless remote for light switch
A number of years ago, I had a Sears garage door opener remote, on which there was a second button with which I could control a special wall switch inside the house from my detatched garage (maybe 75 feet from the switch). Well, the switch wore out and Sears no longer makes them.
I have seen wireless remotes that can contol an outlet, but I can't locate one that will control a wall switch. I wish to be able to control my backyard security lighting from my car.
Anybody have any ideas? Thanks.
jmhultin is offline   Reply With Quote
Old 08-29-2011, 05:53 PM   #2
Master Electrician
Rewards Points: 3,678
Check out Leviton's DHC products.
brric is offline   Reply With Quote
Old 08-29-2011, 06:10 PM   #3
I appreciate your suggestion. In fact, I have checked them out but their transceivers are only for plug-in devices, such as a lamp. They don't seem to have a wall-switch that can be controlled wirelessly.
Old 08-29-2011, 06:31 PM   #4
Master Electrician
I have installed DHC swithches controlled by a key fob. Perhaps they're discontinued but I don't think so.
Old 08-29-2011, 06:36 PM   #5
Ok - thanks. I'll keep researching.
Old 08-29-2011, 06:45 PM   #6
Master Electrician
Key fob is HCCKR-E.. I'm still searching for the correct switch. You can always call Leviton tech support.
I believe the HCCKR for communicates with the HCPRF-1TW plug in transceiver with then communicates with the HCC10-1TW or similar wall switch.
Old 08-29-2011, 07:07 PM   #7
thanks - I have that part number, and the only transceiver that it recommends is HCPRF, which is a plug-in device. It's promo for the key-fob says it can "Turn ON/OFF your home’s entry/exterior, garage and driveway lighting as you approach." That certainly doesn't sound like its limited to plug-in devices, but I can't find anything.
Old 08-29-2011, 07:14 PM   #8
Master Electrician
It is not limited to plug in devices.
FYI thes devices are not cheap.
http://www.google.com/url?sa=t&sourc...y9lpHpK0UM5YKg
http://www.google.com/url?sa=t&sourc...ZS7UkwJ8z48hxA
Leviton tech support:
(800) 824-3005 6:30 am-5 pm PT
Old 08-29-2011, 08:05 PM   #9
Too Short? Cut it Again!
Might see if x-10 components would work for you. I had a system many years ago that worked out great. I did not have a key bob but think they make one.
http://www.x10.com/automation/
Old 08-29-2011, 09:27 PM   #10
Missouri Bound's Avatar
I completely agree with this idea. I have been using X-10 devices for more than 10 years now in my home and they have a huge assortment of controllers and devices.
Old 08-30-2011, 06:13 AM   #11
was also going to suggest x-10 pro. they even have a remote that clips to the visor in the car like a garage door opener. Pretty inexpensive too.
MitNotrof is offline   Reply With Quote
Old 08-30-2011, 10:45 AM   #12
ok - I've looked at the x-10 stuff and that looks promising.
Thanks for all of your suggestions!
Wireless remote for ceiling fan Nasba324 Electrical 2 03-20-2011 08:23 PM
Remote Control Ceiling Fan - switch required? bvbellomo Electrical 7 11-10-2010 09:07 AM
Wireless light switch recalled kbsparky Electrical 1 10-26-2009 07:55 PM
Thermostat w/ wireless Remote Sensor Davidb6 HVAC 2 02-10-2009 08:45 PM
Remote Switch? jasoncw Electrical 11 10-06-2008 10:44 PM
