Wireless Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 06:54 AM   #1
Rewards Points: 874
Wireless lighting
Not sure that this is the right forum as this is wireless. We are thinking about putting wireless lighting, hvac etc. controls in our home. Can you retrofit extg. Lights to be wireless or would new lights have to be bought? Can anyone recommend a system that have heard good things about so I can do some research? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 02-16-2013, 07:16 AM   #2
Rewards Points: 3,130
As I understand it, you don't do anything with the lights, it's the switches that are replaced with wireless ones. How HVAC is done I don't know; probably with a wireless thermostat. There are even ways to control things from a smart phone. Sorry I can't offer more specifics, but I don't have such a system or even know anyone who does. Both Home Depot and Lowe's do sell wireless switches.
Old 02-16-2013, 07:22 AM   #3
Rewards Points: 13,456
Just for my own info, why do you think you want to go that way? One more thing to fail.
Old 02-16-2013, 07:28 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
What are you calling "wireless". Do you mean you want to install a home control system to existing devices/fixtures in your house?
Old 02-16-2013, 08:01 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't get all this wireless/I want to control my home's electric from my iPhone stuff.
I do get the wireless TStat, but I think you'd be better served changing lamps to LED or CFL and leaving select lights on when you are gone. A cheap $5 plug in timer could turn lights on/off when you are on vacation to act as someone is home.
I would be curious to see a homeowner's thinking on this.
Old 02-16-2013, 11:07 AM   #6
MCB
sparky
Wireless is still unreliable and just doesn't last, in my opinion, of course.
If you want cool automated lighting see Lutron's home automation. Pricey but very cool- I'm sure you can program the thing from your phone and have the lights come on when you are arriving home, etc....
MCB is offline   Reply With Quote
Old 02-16-2013, 01:26 PM   #7
Well, this homeowner thinks it's a waste of money. But hey, it's the OP's money.
Old 02-16-2013, 01:30 PM   #8
Missouri Bound's Avatar
Look into X-10 controls. They are cheap and somewhat reliable and it will give you a good idea what you can accomplish. There are several other systems available, but much more costly. X-10 devices have worked for me for over 12 years, and as I said it's very budget friendly.
Do you want it your way or the right way?
Old 02-16-2013, 01:36 PM   #9
Rewards Points: 874
Thanks ..I thought x10 made a crappy product... I will look into it based on your experience. Thanks
Old 02-16-2013, 03:09 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
X-10 is crap, stay away...
Old 02-16-2013, 03:11 PM   #11
E2 Electrician
Scenes is one advantage, but the options are limitless, from security, to having control anywhere in the world... but being able to have pre programmed scenes for parties, to evening to morning routines, touching one button to control all this is well worth it. I sell a lot of Radio Ra 2 installations, the product is simply amazing if you have the coin to do it.
Old 02-16-2013, 05:15 PM   #12
It doesn't work in all situations, but it's inexpensive enough for him to try, and see what wireless will do for him. And he won't have to pay anyone to install it.....
Old 02-16-2013, 09:16 PM   #13
If you want high quality wireless controls you're going to invest quite a bit to do a whole house. That said, the best quality systems I'm aware of are made by Lutron. You should check out their RadioRA product and the Spacer System line. Their tech support is pretty knowledgeable so I'm sure you could call them up and they could give you some good info.
LooseSCruz is offline   Reply With Quote
Old 02-16-2013, 09:44 PM   #14
Semi-Pro Electro-Geek
Rewards Points: 2,922
Radio RA is incredibly annoying to work with and very expensive. I would not recommend it. Only Lutron-certified installers have access to the software needed to configure the system, and you have to buy a LOT of hardware to get it all working. Although the devices are based on the Zigbee mesh-network protocol, they don't actually implement a mesh function, so you need repeaters and often have range issues. And the devices are super expensive. I was forced to use it (by an architect who had never used it before) on a $2.5M home project and the results were more annoying than beneficial. The owner regretted buying into that plan.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-17-2013, 06:08 AM   #15
E2 Electrician
i've never had an issue, and its easy to install and program, and its required to be certified for a reason, it keeps the money in the contractors hands, not joe blow home owner...
Im curious what issues you had though, because its pretty cut and dry and the system works...
Kitchen Remodel LED Lighting Problems jimklug Electrical 2 07-02-2012 01:35 PM
Extending or Modifying Wireless sensor for Tstat kilosos2 HVAC 4 04-15-2012 01:17 PM
Wireless Light Switches (for installing recessed lighting) htabbas Electrical 1 10-30-2011 06:44 AM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
