-   -   Wireless fan and light controls (http://www.diychatroom.com/f18/wireless-fan-light-controls-51529/)
thillygooth 08-23-2009 08:16 PM
I have a room with a ceiling fan/light unit, but theres only 1 switch on the wall. I want to be able to control the fan and light separately without pulling chains on the unit itself.
All I could find is this: http://www.homedepot.com/webapp/wcs/...574&marketID=8
Is this my only option or are there other kinds or other methods I should look into? Thanks
dSilanskas 08-23-2009 08:45 PM
There are many different types of remotes for your fan/light. I have a hand held one that you can take around the room with you. But whatever one you choose remember you still need a switch to disconnect the fan power.
thillygooth 08-23-2009 11:55 PM
The one I posted in the link has 2 switches up in the fan/light fixture itself. The wall unit is just battery powered and radios the command up. Are there any other things like this?
J. V. 08-25-2009 01:22 PM
Don't say that to loud around here. There are several seasoned and well respected electricians on this forum that would disagree with you. That no switch is required on a ceiling fan. Some going as far as to say you can switch the light, but leave the fan hot all the time and use the pull chains. I know, I just had two days of discussion on this exact subject.
You might want to look at the thread. I think is was titled "Installing a ceiling fan". I think. Its a few day old.
Heres the link. http://www.diychatroom.com/f18/insta...ing-fan-51227/
OP. The only other way to have independent control of the fan and light is another wire. You need a 3 wire cable from the switch to the ceiling box. If you have conduit you can easily push a new wire in. Remotes work real well, and do not cost that much. Sometimes it's a bit difficult to get the receiver into the fan canopy.
