Old 01-25-2012, 01:49 PM   #16
wireless electric outlet question
Originally Posted by KimS View Post
ok ok, message received
I meat to be harsh, Fire bad, toxic smoke bad!
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 01-25-2012, 02:00 PM   #17
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Weekend with a wet saw shop vac chiseling cement laying conduit and pouring some hydraulic cement sounds fun to me.
rrolleston is offline   Reply With Quote
Old 01-25-2012, 02:30 PM   #18
Ironlight's Avatar
I checked out the "geek" site. it has a "haha, april fools" under the product so I'm assuming that was a gag.
you know guys, (just to make myself more humiliated), I just thought since you can remote the garage door etc, there might be some kind of product that would work for this earth shattering issue, lol.
Sorry Kim, the link was actually directed at the other fellas here...it was certainly not intended to make you feel bad. And as mentioned the only stupid question is the one you never ask and don't get answered.
You could using something like these under the carpet:
http://www.electriduct.com/Light-Duty-Cord-Covers.html
I may get pounced on for suggesting the less-than-optimal route. And those guards might not work for you because you don't want a hump in or on your carpet. BTW if you put it under the carpet in a guard expect the carpet that runs above it to wear much more rapidly than the rest.
The best solution would be to peel back the carpet and cut a channel into the concrete to run a power line in and then install a receptacle recessed in the floor, but it would be expensive if you don't do it yourself.
Ironlight is offline   Reply With Quote
Old 01-25-2012, 02:46 PM   #19
rrolleston's Avatar
That looks like a good option but I would not put it under a carpet just get a color that matches the carpet or looks good.
Old 01-25-2012, 02:49 PM   #20
We use something similar at work.
Conference table sitting in the middle of the room, power and LAN in the walls, and no one likes to saw cut the floor.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
de-activate 220v electric stove outlet 6fthook Electrical 17 10-04-2011 07:32 PM
outlet question. sanman Electrical 5 07-18-2010 03:37 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
help! with electric outlet Brad325 Electrical 7 05-03-2009 12:01 AM
