Wireless 3 Way Switch, Code? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 12:46 PM   #1
wireless 3 way switch, code?
In the middle of finishing my basement.
Currently there is a switch at the top of the stairway which controls lights at the top and bottom of the stairs. However, it is not a 3 way switch (only controllable from upstairs). Also, it's run with 14-2 wire, so there's really no way for me to change it into one (the wire run would be almost impossible to change to 14-3 without some major deconstruction).
Just wondering if a wireless 3 way switch installed in the basement to control those lights will meet code?
Scott12 is offline   Reply With Quote
Old 03-13-2011, 09:58 AM   #2
Just call me Andrew
Rewards Points: 1,020
Bump for Scott.
My uneducated guess would be yes....
Andrew
secutanudu is offline   Reply With Quote
Old 03-13-2011, 11:58 AM   #3
Is your question whether wireless switches meet code, or whether there is a code requirement for a switch at the bottom of the stairs, or both. My semi-educated guess is yes, to both.
oberkc is offline   Reply With Quote
Old 03-13-2011, 01:16 PM   #4
I=E/R
a7ecorsair's Avatar
Since they are on the market and that they are covered in "Wiring Simplifed" 42nd edition based on the 2008 NEC, I'd say they are permissible. The switch that is connected directly to the structure wiring would be the piece that would be affected by the NEC the most. It will be L&L for this purpose.
a7ecorsair is offline   Reply With Quote
Weatherking pressure switch stuck closed error code bobnorman76 HVAC 0 12-18-2010 10:29 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
