Wireing Motion Dector Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2012, 07:45 PM   #1
wireing motion dector lights
I currently have two seperate flood lights. one on the side of the house, one on the back of the house. i would like to have bothe on MD, and to operate seperatly, Power comes from circiut breaker to light switch which is 12-2. then 12-2 from the switch to the light on back of house. 12-2 from that light to the light on side of house, which runs under the siding. What i did was take the black power from switch and connected to the black MD and the black to the second MD. then connected the white in the same way. tthe reds were already connected together. this works short term then every thing goes off. one light never turns off, and the other blinks on and off. where did I go wrong?
bobjblackwell is offline   Reply With Quote
Old 11-14-2012, 08:15 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If you turn the switch on the lights should come on.
Turn the switch off the on quickly,the lights will come on then go out. And should activate when motion is detecteded. Be sure you have set the delay on the MD also.
sublime2 is offline   Reply With Quote
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 02:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 08:52 AM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 10:39 PM
