Wireing Ac Gearmotor - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 06:37 PM   #1
wireing ac gearmotor
how do I connect ac gearmotor (9k345) 115 VAC with two red & two black wires coming out of it ?
Gkolodziej is offline   Reply With Quote
Old 03-12-2011, 07:40 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,892
Are you sure that's actually a 115VAC motor? Red and black wires on a gear motor would usually suggest low-voltage DC. If it is actually rated for 115VAC, then you would connect either lead to hot and the other to neutral. Connect a ground wire to the case if it's metal.
mpoulton is offline   Reply With Quote
Old 03-12-2011, 08:36 PM   #3
Experienced
Jackofall1's Avatar
Sounds like you need a relay to connect it to, either one relay or two relays and a control for direction, the multiple leads are undoubedly for directional control.
Mark
Old 03-13-2011, 05:11 AM   #4
I was assuming that it ONLY has a red and a black wire, since that's all he mentioned. If there is also a white wire, then you're right - the red and black are the hot connections for opposite directions. It can be controlled with just a single pole double throw switch.
Old 03-13-2011, 08:06 AM   #5
Rewards Points: 506
Follow the diagram on the motor if it has one.
jlmran is offline   Reply With Quote
Fan Wireing Giles Electrical 6 02-23-2011 11:43 AM
wireing a new breaker to one room wolftickets Electrical 4 03-01-2010 01:23 AM
Small Ac Motor Wireing outback HVAC 13 11-06-2009 06:34 PM
Ac GearMotor Wiring Help stevea295 Electrical 10 09-19-2008 11:35 AM
noob wireing question shame302 Electrical 6 05-16-2008 09:33 PM
