Wired Window Sensor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 09:55 AM   #1
Wired window sensor
Hi,
Really basic question here. I am replacing a window that actually has a wired alarm sensor attached to it and the window company asked me to unplug it. I actually don't want to use that sensor again since it is a small window and I don't even use my alarm system.
Can I just cut it, put some electricial tape at the end and hide it in the wall. Is there any fire risk if I do that?
Here is what the sensor looks like:
Thanks!
majas is offline   Reply With Quote
Old 09-24-2011, 10:24 AM   #2
Electrical Contractor
kbsparky's Avatar
If the alarm system is disconnected, then those wires are no longer in use.
Even if they were still in use, they are considered "low voltage" and as such would not pose any fire hazard.
Just snip `em off, and tuck into the wall.
-KB
Old 09-24-2011, 10:40 AM   #3
Thanks a lot!
Was simpler than I thought. Happy not to have called an electrician for this.
Old 09-24-2011, 10:57 AM   #4
Rewards Points: 1,192
Disconnect the wires,wire them together in case you move and new owner wants to use security alarm again. Strong selling point.
bobelectric is offline   Reply With Quote
Old 09-24-2011, 06:11 PM   #5
Rewards Points: 1,532
Why not just leave them up there with the magnet connected in case you or new owner wants to wire it up again you won't have to fish in the wall for it.
bob22 is offline   Reply With Quote
Old 09-25-2011, 11:00 AM   #6
I'll just keep the wires in the wall. This window sensor was kind of useless since it is a very small window (the smallest on the first floor) and leads right in front of a motion detector.
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
Occupancy Sensor: Did I wire it correctly? kohaiut Electrical 7 01-14-2009 11:13 PM
