Is This Wired Right? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 09:26 AM   #1
Is this wired right?
Installing a a New 13 Seer Mini split 18000 btu. Electrician is running 12-3 wire off a double pole 20 amp breaker to the outside unit. The unit is 208/230 V 60htz with the Data Plate calling for a Min amp 13, Max fuse of 15 amp. There is also a 30 amp disconnect box on the outside. I can do a lot of things, electrical is not my stongest attribute. Does this sound right? Thanks
skyhook is offline   Reply With Quote
Old 03-22-2010, 09:37 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
The 12/3 is ok, the 30 amp disco. is ok, but the data calls for 15 amp fuses max, so somewhere there needs to be 15 amp fuses feeding the ac.
jbfan is online now   Reply With Quote
Old 03-22-2010, 09:41 AM   #3
so the double pole 20 in the main box is not gonna work?
Old 03-22-2010, 09:48 AM   #4
Master Electrician
Rewards Points: 3,822
Does the unit say max fuse only, or does it say max fuse or breaker?
brric is offline   Reply With Quote
Old 03-22-2010, 09:49 AM   #5
Master Electrician
Those minimum maximums don't sound correct to me, do they to you jbfan?
Old 03-22-2010, 09:54 AM   #6
Max Fuse/HACR Circuit Breaker
Old 03-22-2010, 10:15 AM   #7
Master Electrician
A 15 amp HACR breaker will suffice.
Old 03-22-2010, 10:18 AM   #8
Thanks for the help. We'll see what happens
Old 03-22-2010, 10:29 AM   #9
jbfan's Avatar
Rewards Points: 400
I have never seen one that tight, but I just install the power the way the data sheet reads.
Like brric said, a 2 pole 15 amp hacr breaker will do.
Old 03-22-2010, 01:41 PM   #10
We'll see. All that info is straight off the data plate. He said he'll wire the 15 amp breaker to the 30 amp disconnect then to the compressor with more 12-3. I reckon, he knnows what he's doing, but it just doesn't sound right to me. Seems it should be more. Thanks for the help fellas..............
Old 03-22-2010, 01:57 PM   #11
jbfan's Avatar
Rewards Points: 400
Thats right.
From the breaker panel with the correct size breaker, to the disconnect.
It does not matter what size the disconnect is rated, because the breaker protects the wiring.
The disconnect is just used to service the equipment.
The Following User Says Thank You to jbfan For This Useful Post:
skyhook (03-23-2010)
Newly wired doorbell not working GoPens Electrical 8 08-15-2009 08:58 AM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
Wired workshop LDO Electrical 19 08-29-2008 03:45 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Is this outlet wired correctly? NotSoHandyDan Electrical 14 04-11-2008 08:56 PM
