Old 04-28-2010, 10:06 PM   #1
Question
Wired a new light now dimmer doesn't work
I was replacing three pendant lights in my kitchen. The first two are on the same dimmer switch. The third is on its own dimmer switch. The first two light I was able to put up with no problems....connected the white to white, black to black and ground. The third light had different wiring. There was two white (wound together as one), two black (wound together again as one) then a single red wire and a copper ground wire. The light fixture only has a black, white and ground wire. When I hooked it up, leaving the single red wire capped, the dimmer switch no longer works to control it however the switch that normally just turns on the recessed lighting now controls that pendant light. I am stumped. Any help would be appreciated very much. House is only 7 years old...in case that helps.
Thank you!
Smaster is offline   Reply With Quote
Old 04-28-2010, 10:09 PM   #2
Electrical Contractor
Move the black wire on the light to the red wire.
Leave the two black wires connected and the dimmer should work.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 04-28-2010, 10:10 PM   #3
Electrician
Put a marrete on the blacks and connect your light to the red. Sounds like they ran a 3 wire for the lights, the black controls the recessed lights, and the red controls the light your trying to work.
Are both switches in the same box, if so what I said enough is probably whats going on.
darren is offline   Reply With Quote
Old 05-01-2010, 05:38 PM   #4
Thank you for your responses, I appreciate it. So I did as you both said however now the light comes on when I turn the circuit breaker back on and does not turn on or off by any switch only turns off if I use the circuit breaker.............any other ideas? Stumped.
Old 05-01-2010, 05:45 PM   #5
kbsparky's Avatar
Blown dimmer. Especially if that loose red wire managed to ground itself out when no light was attached to it.
-KB
Old 05-01-2010, 05:51 PM   #6
disconnect wires from dimmer see if light stays off if so replace dimmer as mentioned
kennzz05 is offline   Reply With Quote
Tags
dimmer not working, pendant light, wiring with extra wires
Bathroom fan and light wired independently at end of circuit? Alexi637 Electrical 4 03-08-2010 10:32 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
light will not work jcjc320 Electrical 12 07-15-2009 08:18 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
light dimmer problem DXL Electrical 5 03-30-2008 10:03 PM
