Only item I did see so far that need to be done unless you allready did this part you will need NM clamp to hold the NM at the load centre { breaker box }
To seal the conduit you use the electrical putty it will look like playdough putty but it have some nice feature it will never dryout.
A tip with AFCI circuits and GFCI breaker location as well I take a tape or ziptie and bundle it so I know it is either GFCI or AFCI breaker.
The last House I did in USA { wisconsin } we don't have AFCI requirement yet but it is optional so my customer request it so I went ahead and install it and use the Ziptie and that really save my headahce to find the correct pairs to get the AFCI function properly { BTW the inspector like my idea
And with your GE box that is 32/40 box so you allready used up the spaces for tandem so the rest of space is full size single or two pole breakers.
Merci.Marc
