Is This Wired Correct - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 09:09 PM   #1
Is this wired correct
http://photos-e.ak.fbcdn.net/hphotos...68548402_s.jpg
Is this wiring correct? Both outlets worked but it only had 1 white, 1 black wire and the copper wire on the bottom. Came home and this outlet smelled like burnt plastic. The breaker trips a lot for this outlet. The break controls this outlet and the outside outlets, one which is hooked up to the pool pump.
mdoan is offline   Reply With Quote
Old 09-09-2011, 09:20 PM   #2
I=E/R
a7ecorsair's Avatar
The picture is too small to see.
If this receptacle only had a white and black wire then it is the end of the run. What did you have plugged into this receptacle?
a7ecorsair is offline   Reply With Quote
Old 09-09-2011, 09:21 PM   #3
If there's only 1 black and 1 white wire to receptacle outlet, it's the last in the circuit run from the breaker box.
If there's a pool filter on same circuit, best to not use the one indoors at same time. Outdoor outlets should be GFI type for wet environment. If originally known that a pool filter would be used, heavier wiring and outlets should have been planned. If it's a 15amp breaker, it's probably working very hard and hot.
diyorpay is offline   Reply With Quote
Old 09-09-2011, 09:22 PM   #4
Licensed electrician
Rewards Points: 1,630
The pic is too small to see enough detail. It sounds like it is an end of the run since you only have the three connections.
Old 09-09-2011, 10:27 PM   #5
The breaker is turned off for now. It is raining outside currently and the cord from the pool is soaked. Only thing that is plugged into the stinky outlet ISA straightener.
Honeywell wired and wireless? stephmoreland HVAC 8 09-23-2010 07:33 PM
show me your neatly wired panels? dkliman Electrical 25 08-31-2010 01:37 PM
IS it correct? allawi Building & Construction 3 11-09-2009 06:49 AM
Correct oil level in Bristol compressor Aptguy HVAC 5 08-26-2009 09:56 AM
How do I pick the correct coaxial cable? fwmcbigfoot Home Theater 1 12-30-2008 09:45 AM
