Wire For Underground/ Outdoor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 09:54 AM   #1
wire for underground/ outdoor
I am putting a post lamp beside my sidewalk about 35' from my garage. I need to run a wire underground to this location. What type of wire do I need to use for this application. Does it need to go in conduit? Ive heard that outdoor romex in conduit is not acceptable. thanks
mharwell01 is offline   Reply With Quote
Old 09-13-2009, 10:01 AM   #2
If you GFCI protect it 1st you can bury UF wire (grey) in the ground at 12"
It must be protected where it enters the ground & where it comes up for the lamp post - grey electric PVC
You can put reg NMB in conduit (sized correctly) - BUT it is not rated to be buried in the ground or used under ground in conduit
Old 09-13-2009, 10:16 AM   #3
thanks. the first outlet on the circuit is a GFCI. I plan to branch from one of my garage outlets to the lamp post. If I understand correctly, I just need to run conduit down the wall to the ground and then the wire only (no conduit) in the ground to the lamp post. And use UF wire.
Old 09-13-2009, 11:50 AM   #4
Rewards Points: 204
Are you using a switch, photocell or both?
Yes, protect the UF cable coming down the wall and also at the light pole.
Why not just run conduit all the way. You have to dig a trench anyway. You will not have to dig as deep and it makes for a much better job. I believe if the circuit is GFCI protected, the conduit only needs to be 12" deep. You will use separate wires, not cables if you go with conduit.
If it worked before you worked on it. You did something wrong.
Old 09-13-2009, 01:50 PM   #5
yes the post has an outlet and a photocell. i can use conduit all the way. i was going to put conduit into the concrete base and elbow it to come out the center of the top of the base and into the bottom of the post. thanks for the info.
Outlet With Swith and Older (White, Black, Red) Wire CaptChaos Electrical 18 09-14-2009 11:17 PM
What is the best way to wire this? RST Electrical 8 08-18-2009 11:29 PM
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 11:46 AM
Red wire is HOT genner Electrical 15 02-22-2009 08:14 PM
Indoor wire vs outdoor wire Potomac101 Electrical 2 12-31-2007 03:00 PM
