Wire Under House Not Fully Enclosed (what Wire To Use) - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 12:37 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Wire under house not fully enclosed (what wire to use)
HI again;
Other side of house here from previous questions. Front side of the house has a fully enclosed room "porch" with a regular roof on it, carpeted, furnished, etc, but unheated.
The floor is about 5' off of ground level. There is no slab or basement under this area, just footings on the outside corners. There is about 10 inches from the ground to to bottom of the outside wall that is open, i.e. you have to crawl under it to access the space under the "porch".
Currently the outlets on this "porch" are wired with standard romex. When new wires are run, in the joists under this porch space, can they be standard romex / smurf? or do they have to be weather proof, even though water would never be able to get to them?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-02-2009, 12:47 PM   #2
There has been alot of talk about things like this. Reading 334.12 (B) (4) says that NM,NMC, and NMS cannot subject to excessive moisture. (2005 nec)
Personally, I might use smurf.
I think its what the inspector wants. They might consider it a "damp" location.
rgsgww is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
Wire for main panels scrayzee21 Electrical 3 10-18-2008 12:35 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
