-   -   Wire type for extensions to reach breakers (http://www.diychatroom.com/f18/wire-type-extensions-reach-breakers-161042/)
broecher 10-24-2012 02:10 PM
I just upgraded to a 200amp breaker box and some of the branch circuit wires were not long enough to reach down to the breakers. I bought some wire to make extensions and wire-nutted them on. They are copper and match the gauge of the circuit wires I extended.
I understand this is allowable, but now I am wondering if I bought the correct type of wire.
The following is printed on the wire:
SOUTHWIRE E23919 (UL) (AWG 12) 3.307 mm2 Cu TYPE THHN or THWN 600 V gasoline and oil resistant II or AWM VW-1 --- CSA T90 NYLON OR TWN75 600V FT1 NOM - ANCE 90 DEG C --- RoHS
Thanks!
jbfan 10-24-2012 02:27 PM
That is ok if you are in the states, but if you are in Canada, then I don't think you can splice in the panel.
rjniles 10-24-2012 03:07 PM
Assuming you were extending #12 or #14 (20 amp or 15 amp) wires that is fine. Most people would remove the conductors from 12-2 NM cable and use that.
broecher 10-24-2012 05:14 PM
Yeah im in the states - didn't have any NM cable so I just went straight to the single wires. Didn't think anything of it until I remembered that some of that wire is only for cars.
So you think that type of wire is OK and should pass inspection?
rjniles 10-24-2012 05:23 PM
You are good with that.
funfool 10-24-2012 05:37 PM
I went through this with my house when upgrading from old 100 amp to new 200 amp service panel. The service panel is considered as a junction box, and wire nutting longer wires in it is acceptable.
What I have found, when a homeowner does work on their house, the electrical inspectors will bully you.
I know the inspector I had, would nit pick any little thing that may be questionable.
If in doubt, it is only a few inches of wiring, just replace with exactly same wire you have now. Then they cant complain.
They will complain, but not about that.
I once had on a old house the electric meter base was old and needed to be replaced.
I replaced it and did it to code, The inspector told me "we can do better on the grounding"
The line men from the power company was standing there ready to turn me back on.
All they could do was shake there head. I sat all weekend with no power in January, They showed up Monday about 12:00 before going to lunch, still no re-inspection yet.
I showed them that I complied to the inspectors demands and they fired me up anyways. Told me they would loan me the tools needed to go to the inspectors house and turn his power off, as they were leaving.
Just do not give a inspector a chance to bully you, A licensed electrician they can not get away with it.
broecher 10-24-2012 07:35 PM
No problems with the inspectors here. Had two different guys and they have been really helpful. Just don't want to make them have to come again to re-inspect.
Missouri Bound 10-24-2012 07:49 PM
Hopefully you used the same color wires for the extensions.......right?
broecher 10-24-2012 08:22 PM
Yes I did use the same color! I debated that but opted to do it.. It is required?
Missouri Bound 10-24-2012 08:25 PM
Think about it. If you were running a circuit would you change color as you went along? I guess a cheeshead would.
k_buz 10-24-2012 08:26 PM
Nope
:no:
broecher 10-24-2012 08:28 PM
haha I'm still glad I did it. It would be chaotic if it changed colors!!
mpoulton 10-24-2012 09:07 PM
Originally Posted by k_buz (Post 1037407)
Nope
:no:
Well... It's not required that he use exactly the same color, but the rules don't really give too much leeway. The grounds must be green or bare and the neutrals must be white or grey. The hots can be any color other than those - but it would be pretty odd to use blue/brown/orange/yellow so the practical choice is really black or red. He could have chosen ONLY black or red though, rather than using both. I would probably have just gotten a roll of black #12 for all the hots.
broecher 10-24-2012 09:44 PM
That's interesting. I did have one wire that was funny. I'm in a 1960 house so there is old stuff but this wire looks 'new'. It has a white, a grey, and a thinner white that looks like it has two small conductors in it but when you strip it, there is only one conductor. I interpreted this as white = neutral , grey = hot, funny little wire = ground. The outer sheath was light blue. Does this wire type ring a bell? Should I post a pick?
mpoulton 10-24-2012 10:52 PM
I've never heard of such a thing, and would love to see it.
