Wire Tracing Tool Made From Old Phone - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 07:36 AM   #1
Location: Jackson, TN (grew up in Finger(pronounced Fanger in the South)
Wire tracing tool made from old phone
I've worked on jobs where the electricians had made their own tool for tracing a wire when there were multiple wires in a conduit. They used two old telephone receivers, one with a 9volt battery attached. Does anyone know how to make one of these?
Thanks,
sthdbike
sthdbike is offline   Reply With Quote
Old 12-05-2009, 09:33 AM   #2
A "tone generator" and "inductive pick-up" set is better because this will allow you to find wires in walls. Connect tone generator to a wire, then you can trace the wire through the wall with the inductive pick-up.
The old type did not have its own speaker. You would connect a telephone technician's handset to the inductive pick-up to hear the sound.
Set like this...
(Get at electrical supply)
http://www.tvcinc.com/products_detai...roduct_id=1025
More...
http://images.google.com/images?hl=e...=&aqi=&start=0
Billy_Bob is offline   Reply With Quote
Old 12-05-2009, 12:07 PM   #3
Thanks so much for the reply. I have some wires in a conduit from my shop to the upstairs of my shop. When I pulled them, I had them marked. Some of the kids thought the tape markings on the wires coming out of the box looked like fun to pull off, and that's where I'm at. I could use an ohm meter and have my son go upstairs to touch wires together(I do have a couple of wires that are still marked) but I also have a couple of old phone handsets that are laying around. I thought it would be neat to make my own and have around if I ever needed them.
Old 12-05-2009, 12:18 PM   #4
For that you can just short two wires together at one end, then test with an ohm meter on the other end. Only the two wires shorted would show a reading.
Using alligator test wires would be handy for this. Like these...
Old 12-05-2009, 12:19 PM   #5
How to test for continuity...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Old 12-05-2009, 02:04 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Cheapest way to go. I've done this countless times when tracing wire in my new house to know where it's going. Turn power off of course! (preferably the main)
Old 12-05-2009, 03:02 PM   #7
I was talking to an electrician and he told me that in the old days they used to use phone handsets like that to talk to the guy in the crawlspace (now they use radios). You could probably figure it out by opening a handset on a working phone and testing for voltage. I think you just power the part you talk into.
pyper is offline   Reply With Quote
Old 12-05-2009, 03:34 PM   #8
Here is how to get two phones talking to each other...
(Disconnected from your phone line of course!)
http://www.epanorama.net/documents/t..._intercom.html
Old 12-05-2009, 04:16 PM   #9
But that's whole phones.
This is just the handsets connected with wires.
Old 12-05-2009, 09:59 PM   #10
You have a red and green wire in the hand set. Cut the red or the green wire inside or outside of one of the handsets and insert the battery connections on the cut ends. Add alligator clips to the ends of the wires.
hayewe farm is offline   Reply With Quote
Old 12-05-2009, 10:22 PM   #11
What about the other handset? Cut same wires and add alligator clips to the same wires and attach them to the wires I'm testing, as long as I know one common wire?
Old 12-06-2009, 11:26 PM   #12
Yes, once the hand sets are connected together you can talk back and forth.
Old 12-07-2009, 12:41 AM   #13
I leave Monday on a 4 day job in Columbus MS. Can't wait to get home and fix them up. Sure appreciate the advice and will let you know how it turns out.
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
phone wiring Potomac101 Electrical 8 02-11-2008 04:23 PM
phone wire JAVAMAN General DIY Discussions 7 12-14-2007 02:42 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 04:48 PM
New Phone Jack Install - Q & A 101 allen1466 Electrical 7 07-18-2007 12:46 AM
