#1 |
Wire through cinder block
I am relocating my washer dryer. I need to run the wire through cinder block than about 20 feet outside and back in through wood. Questions as follows:
1. Where the current outlet for dryer is located is about 4 plus feet above ground. I will be putting a vanity here (currently w/d is in bathroom). At this height the box will not be in the vanity cabinet so I think I need to lower it so its not visible and enclose in a junction box. What is cleanest way to go through cinder block? I know to drill hole but how do I "attach" the conduit on the cinder block? Is there some sort of threaded fitting? 2. Once I have the wire outside and in conduit do I run above ground to new location in conduit or just bury some sort of waterproof line (romex?) below ground and than come up at new location? 3. Lastly, instead of dealing with a new junction box at lower height to be hidden in cabinet can I splice new wire use wire nuts and just hide behind paneling I am putting up? I know code probably calls for a junction box but if I do work myself do I need to follow code? Thanks |
#2 | ||||
Here is how I would respond to a few of these:
| Display Modes | |
| How to Repair Cinder Block Foundation Cracks | Germwise | Building & Construction | 4 | 07-01-2010 12:14 PM |
| building concrete steps cinder block frame? | drewhart | Building & Construction | 2 | 06-10-2010 02:48 PM |
| HALP! Master/Remote Dimmer troubles! | Confuserated | Electrical | 9 | 02-12-2010 04:30 PM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| Cinder block wall hangings | shnfldr | Remodeling | 2 | 06-07-2008 09:26 AM |
