Wire Through Block And Brick - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 06:11 PM   #1
Rewards Points: 225
wire through block and brick
Running a 12/2 wire through double layer of brick on one side and looks like concrete block on the other side. Thickness 8" approx. On one side of the wall is a 2x8 that the wire also has to go through. The wire is for a GFI. The wall is interior on both sides not exterior. Garage one side. Need to use pvc or metal conduit? Size of pipe for 12/2 wire? What type of fittings for the ends? The wire is going to the circuit breaker box. Thanks.
gt1935 is offline   Reply With Quote
Old 11-02-2012, 06:57 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 654
Conduit is not needed unless you just want it for protection against abrasions.
jbfan is online now   Reply With Quote
Old 11-02-2012, 09:04 PM   #3
Rewards Points: 225
Abrasions from pulling wire through? Slowly pulling wire through work? Thanks.
Old 11-03-2012, 05:38 PM   #4
Julius793's Avatar
As stated you don't need conduit just keep in mind you can not cement it inside the wall unless its in conduit.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Block and Brick Ledge Rleeshfr Concrete, Stone & Masonry 4 08-09-2012 12:38 AM
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 09:46 AM
glass block perimeter channel in brick wall amakarevic Building & Construction 10 05-03-2011 09:12 PM
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 04:45 PM
block and brick Toolmaster Building & Construction 7 08-31-2009 12:57 PM
