Old 05-14-2012, 07:32 AM   #1
Wire for subpanel
Hi,
Can I run 8-4 TYPE SOW 90C (-40C) 600V WATER RESISTANT CSA WIRE from my mine to sub panel? Both in finished basement. I plan 50-60 Amp subpanel.
Alex
avgor is offline   Reply With Quote
Old 05-14-2012, 07:48 AM   #2
Code05's Avatar
Wire for subpanel
No. SOW is a cord and #8 is too small for 50-60 amp panel.
Code05 is offline   Reply With Quote
Old 05-14-2012, 08:37 AM   #3
Wire for subpanel
Ok. Thanks.
Old 05-14-2012, 09:32 AM   #4
Licensed electrician
Wire for subpanel
Flex cord cannot be used as a substitute for permanent wiring.
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
