Wire Sizing For Wall Heater? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 03:06 PM   #16
Electrician
Rewards Points: 794
I did not mention it because the amperage was so low.
Anyways would it not be 6.25X125% not 6.25+125%. Which would give you 7.8A. I live in Canada and only know the Canadian Electric Code which treats the load differnetly then other loads but this could be rule of the NEC.
darren is offline   Reply With Quote
Old 09-21-2008, 03:09 PM   #17
Electrician
Try it either way and see what you end up with.
chris75 is offline   Reply With Quote
Old 09-21-2008, 03:50 PM   #18
You end up with two different numbers. 7.81 and 14.06
jerryh3 is offline   Reply With Quote
Old 09-21-2008, 03:58 PM   #19
Electrician
I couldn't come up with 14.06, what am I doing wrong?
Old 09-21-2008, 04:04 PM   #20
Electrician
Rewards Points: 794
Chris they took 6.5x125% and then added that number to 6.5 to get you the 14A.
If you add or multiply you get the same answer, i just have never seen it written or said as adding 125%.
We both meant the same thing but written two different ways.
Old 09-21-2008, 04:08 PM   #21
125% of a number is the number plus 25%. When you say take the number and add 125% you're actually saying take x and add it to x*1.25. It should be take the number and add 25%.
Old 09-21-2008, 05:04 PM   #22
Electrician
I know, I was not sure how you guys were coming up with 14 amps, most people, I thought would just multiply by 1.25, guess I thought wrong.
Old 09-21-2008, 09:59 PM   #23
Electrical Contractor
kbsparky's Avatar
... I thought would just multiply by 1.25, guess I thought wrong.
Nope, you thought right.
You can EITHER take the full load and multiply by 1.25 OR you can take 125% of the full load. Both are the same thing.
You do NOT take the full load and add another 125% to that. Overkill, big time.
I get 7.8 Amps total needed for this circuit. Slightly over half of what a 15 Amp circuit can safely provide.
Tags
gauge , heater , volts
How to wire a US tankless water heater in Italy The Duck Electrical 1 09-04-2008 09:18 PM
how to wire an electric heater murray59 Electrical 8 04-26-2008 11:21 AM
Sizing a hot water heater. Randell Tarin Plumbing 2 01-26-2008 05:02 PM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 08:42 AM
Help with wire sizing pdxoregon Electrical 2 08-17-2006 07:15 PM
