Wire Sizing - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2008, 09:08 AM   #1
Wire sizing
Good morning,
I want to install a sub-panel in my shop. I have a 100 amp, GE model. Can I use 6-3 wire from my main panel to the new sub-panel?
Mike
rtyui2 is offline   Reply With Quote
Old 04-20-2008, 09:32 AM   #2
joed's Avatar
Rewards Points: 13,330
You can if you use a 60 amp breaker.
Old 04-20-2008, 09:32 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Yes. Depending on the distance you can breaker this at no more than 60A in the main panel.
The 100A panel is just the maximum rating. You can feed it with 60A, or less.
Old 04-20-2008, 11:56 AM   #4
Idiot Emeritus
Rewards Points: 1,492
The above posts are exactly correct, I'd like to add; is this wire a 6/3 with ground? To feed a subpanel, you need 2 hots, 1 neutral, and 1 ground. 4 wires total.
Rob
micromind is offline   Reply With Quote
Old 04-21-2008, 04:29 PM   #5
Master Of Nothing
mr500's Avatar
Originally Posted by rtyui2 View Post
Good morning,
Mike
I just finished this project this weekend. I used #3 and #8 for Eq ground. Let me tell you that #3 kicked my A#^. BUT if you want more amps you have to up the wire size. I was going to go with a 60 amp, but decided as long as im running conduit and things might as well run bigger wire for 100amp and thats what I did.
Just know that the ground and neutral have to be separated (different busses) AT the sub panel. I had to go buy and equipment ground buss for my GE box seeing how it did not come with one. But there available. everywhere.
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Help with wire sizing pdxoregon Electrical 2 08-17-2006 07:15 PM
