Wire Size And Type To Use - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 06:54 PM   #1
Wire size and type to use
I am trying it figure out what type of wire I need to run from a remote electrical pedestal to my proposed cabin. The cabin will be less than 500 square feet and have a refrigarator, and possible electric stove. No washer or dryer. The rest of the cabin will have the basic outlets and lights. The distance from the pedestal to the cabin is about 110 feet. I want to use a direct bury cable but want to make sure i buy the proper wire to use. I have had several different recommendations which has made this exercise more confusing. Please help
In2dux is offline   Reply With Quote
Old 09-28-2012, 07:24 PM   #2
Electrical Contractor
jbfan's Avatar
Size depends on the stove being there or not being there.
The stove could be a min. of 40 amps.
jbfan is online now   Reply With Quote
Old 09-28-2012, 09:27 PM   #3
Missouri Bound's Avatar
Unless you know the electrical requirements you will have at the cabin nobody can advise as to which wire size to use.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Speedy Petey (09-29-2012)
Old 09-28-2012, 11:42 PM   #4
Code05's Avatar
Rewards Points: 1,104
I'll say 750 kcmil CU just to be on the safe side.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
Speedy Petey (09-29-2012), stickboy1375 (09-29-2012)
Old 09-29-2012, 03:46 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,902
If the cabin qualifies as a "dwelling" for code purposes, then it is required to have at least 100A service. 100A is plenty for what you're doing, unless you have electric heat or tankless electric hot water. If you use gas for all heating and cooking appliances and are not subject to the dwelling code requirement, then you could probably get by with 40-60A with no problems. But we'd need to know the actual specs of the equipment you're installing.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
jrclen (09-29-2012), Speedy Petey (09-29-2012)
Old 09-29-2012, 04:02 PM   #6
Rewards Points: 1,192
100 amp.When you get the boot,you can run an electric heater.
bobelectric is offline   Reply With Quote
What size and type wire should I use? Iman Electrical 4 06-20-2010 02:57 AM
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 11:54 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 09:13 PM
Please confirm wire size and type for amperage. wantsomegetsome Electrical 14 05-07-2009 06:49 AM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 09:31 PM
