Wire Size To Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 06:58 AM   #1
zom
Wire size to sub panel
I'm sure this question has been asked lots of times here, & I've done multiple searches, but I can't seem to find an answer to my question. If it has been answered before & someone has a link, I'll be more than happy with it.
This is what I currently have: I have installed a 100amp Square D subpanel in my detached garage. The panel will be fed from a 60 amp breaker from the main panel. This sub panel will feed three 15 amp circuits (1 for lights, 2 for outlets), plus a 30 amp 220 circuit. I currently do not have anything that runs 220, but want it for future use, just in case. Outlets will only be used for light hand tools, battery chargers, torpedo heater, etc. I'm sure I went overkill on the number of circuits, especially since this is only an 18 x 18 building.
The sub panel is located 125' from the main. I had planned on going underground in PVC. I cannot seem to get a straight answer on what guage wire I need. Can I get away with #6 copper? Or should I go #4. I plan on running a 4 wire feeder.
A licensed electrician will do the final hook up, I'm just trying to do the easier stuff myself.
If I have left out any details, let me know & I'll fill them in.
Thanks for your time.
Chad
zom is offline   Reply With Quote
Old 06-03-2011, 07:33 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 246
3 #6, and 1 #10 for the ground, and ground rods at the building.
Old 06-03-2011, 07:39 AM   #3
zom
Perfect. Thanks for the extremely quick reply.
Chad
Old 06-03-2011, 10:15 AM   #4
Rewards Points: 1,016
Very similar to what I did last year to my workshop - see #5 in this thread
Running a 60 amp panel from a detached garage 75 feet away
Old 06-03-2011, 10:46 AM   #5
Lost..
Rewards Points: 336
See here:
Do I need a sub panel here?
What I'm doing is very similar. Alot of reading in my thread, but my situation is almost just like yours. I chose to go with 2,2,2,4 Aluminum feeder wire, commonly called "mobile home feeder." I bought 85 feet of it last night for about $185. It is significantly cheaper than copper and you can run more amps. Not that you would need it, but it will be there.
J S Machine is offline   Reply With Quote
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 10:41 AM
What size breaker and wire ? baddley Electrical 6 02-15-2011 12:12 PM
What size wire for 100 amp sub panel Bean Electrical 7 01-24-2010 08:31 PM
Max sub panel for 10-4 wire beefjerkyboy Electrical 14 05-16-2009 11:44 AM
Panel Upgrades and Aluminum Wire Fearless Freep Electrical 17 10-02-2008 01:45 PM
