Wire Size For Small Shop - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2011, 12:14 PM   #1
wire size for small shop
I have a farm service at my power pole and am buiding a shop that is 330 ft away (from pole box down 30 inches and across to service panel) I am going to use a 100 amp service panel and would have lights, plugs, garage door opener, a 30 amp rv plug and once in a while I might use a welder requiring a 50 amp breaker. what size of wire would I need and is it cheaper to use aluminium or copper.
d.simard is offline   Reply With Quote
Old 09-21-2011, 01:06 PM   #2
Code05's Avatar
Rewards Points: 1,104
I assume your actually needs will not exceed 70 to 80 amps even with the welder, if it were me I would run #2 aluminum.
Opinions will vary.
Code05 is offline   Reply With Quote
What size wire to use running underground ms66cadillac Electrical 21 01-13-2011 11:14 AM
Sub-panel selewis Electrical 23 02-21-2010 10:52 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 08:13 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
