Wire Size For Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 08:13 PM   #1
PPBART's Avatar
Rewards Points: 329
Wire Size for Receptacles
Can someone tell me when the requirement for #14 max wire size for 120v 15A receptacles came about? My house was built about 20 years ago and circuits were wired with #12 solid CU. I've recently had to change out some receptacles and find that all the new ones will accept #14 max for the stab-in connection. I was able to install the new receptacles by using the side screws --a lot more work(!), but not much choice.
PPBART is offline   Reply With Quote
Old 11-10-2011, 08:15 PM   #2
Sparky
Rewards Points: 510
the spring style stab in connections have been #14 only for many many years(15+ i would say). the screws are by far the better choice anyway.
Techy is offline   Reply With Quote
Old 11-10-2011, 09:22 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
A bit of advice.....do not use the back stab feature of recepticles.....that is one of the most common sources of failure....
12 Awg is the standard for wall recpt. Even though your outlet might be a 15A recpt....the ckt feeding it is also feeding several other outlets....hence, 20A.
Unless the outlet is the last outlet in the string, the outlet has another set of wires going to the next outlet.
When you use the back stab feature of the outlet, you are depending on the small contact area of a spring loaded blade on to the side of a round wire. On a good day, you 'might' get 20% surface contact. Couple that with the daisy chain of other outlets.....your setting yourself up for failure.
I personally think that the back stab feature on outlets should be removed.
Old 11-10-2011, 09:55 PM   #4
Electrician
Rewards Points: 794
Backstab should be stopped but all plugs should have screw down clamps on them, no need to put loops in the wire and get it to fit under the screw.
darren is offline   Reply With Quote
Old 11-11-2011, 05:22 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I have to say, this part is a bit over dramatic. It's NOT "a lot" more work. Not even close. Especially for just "some receptacles".
Ask ANY electrician and they'll tell you that back stab connections on receptacles is one of the most failure prone things in our work. THIS is why you can only use #14 with that function. The added load typically seen on a 20A circuit compared to a 15A makes these failures even more likely.
#14 is NOT the max size you can use, it's just the max size a back stab will accept.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (11-12-2011), jimmy21 (11-11-2011)
Old 11-11-2011, 06:44 AM   #6
PPBART's Avatar
Rewards Points: 329
Originally Posted by Speedy Petey View Post
...It's NOT "a lot" more work. Not even close. Especially for just "some receptacles".
Ask ANY electrician...
LOL! If I were an electrician, I'm sure it would have been less of an issue. However, if I were an electrician I probably would not be asking the question here.
And I thought I made it clear that I was referring to #14 as the max size for back stab, since I stated that I connected the #12 to the side screws(?)
Anyway, thanks for the good info about the potential disadvantages of the stab connections -- I'll certainly keep that in mind for future projects.
Old 11-11-2011, 10:56 AM   #7
liscenced electrician
Rewards Points: 538
Another electrician and I can't stress enough how bad the stab in the backs are. They do not hold up and you will soon be tracking down a loose connection
jimmy21 is offline   Reply With Quote
Old 11-11-2011, 10:56 PM   #8
Missouri Bound's Avatar
PPBART The better, higher quality receptacles have clamps. Whenever you replace a receptacle, spend a little more and get the better ones.
Old 11-12-2011, 12:00 AM   #9
Rewards Points: 538
This is actually very true. If you ever break a receptacle open, you will know why. The cheap receptacles just have metal that spreads apart when you plug something in. When you unplug it, it has enough memory to spring back closed. This isn't the case forever, eventually they become loose and make a crap connection. The good receptacles have a spring loaded tab that spreads apart and the spring puts the pressure on. Should make a good connection forever.
Old 11-12-2011, 07:52 AM   #10
PPBART's Avatar
Rewards Points: 329
Originally Posted by jimmy21 View Post
...If you ever break a receptacle open, you will know why...
I took an old receptacle and broke it open to examine that clamping mechanism and I see what you mean. Guess we've been fortunate that (to the best of my memory) we've only had a couple of receptacles actually fail so far in our 20-year old house -- or maybe the hardware was a bit stouter back then(?) Anyway, I'll happily use the side screws for any future replacements.
Old 11-12-2011, 10:01 AM   #11
Rewards Points: 538
I was more referring to the front of the receptacle but yes, the stab in the backs are worthless
Old 11-12-2011, 12:20 PM   #12
PPBART's Avatar
Rewards Points: 329
OK, I re-read your post and understand, took another look at that receptacle I broke open and see what you mean. Thanks for the info.
Old 11-12-2011, 01:46 PM   #13
Rewards Points: 538
the old saying is true, you get what you pay for. There is a reason that cheap receptacles are cheap. I do use them sometime in spots that stuff isn't going to be plugged in and unplugged all the time. The more you plug and unplug a cheap receptacle, the faster they wear out. In spots that are going to constantly plugging in and unplugging i always make sure to use a commercial rated receptacle
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
