Wire Size Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 09:23 PM   #1
analogmusicman's Avatar
Rewards Points: 560
wire size question
we bought this nice light fixture for the family room. it hangs on a chain. since the wire and chain that came with it is too short (the lamp has to be "swagged" to get it in the right spot) we bought some longer wire and chain. unfortunately, the wire I bought is larger than the original. yes,it fits through that hollow "thingamajig" up into the ceiling box but there's not much more room for a "ground" wire to the lamp.
my question is twofold: first,is that ground really needed? second, if it IS needed,how small a wire can I use?
tnx,
analogmusicman is offline   Reply With Quote
Old 08-31-2011, 09:55 PM   #2
Rewards Points: 560
hmm...no answers. maybe I'll ask this a bit differently: "what wire gauge does code indicate for a ground wire to a light fixture"?
tnx,
Old 08-31-2011, 10:23 PM   #3
Code05's Avatar
Rewards Points: 1,104
In the absence of a UL listing for a reduced ground, which most fixtures have, I imagine you would have to default to T250.122 and use a #14.
However; having a ground larger than the hot and neutral would be silly.
Code05 is offline   Reply With Quote
Old 09-01-2011, 07:47 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
If the fixture has exposed metal parts it should have come with a ‘ground tail’, so yes, it too would have to be extended. I would apply 250.122 (A) & (E). The EGC shall not be smaller than 18 AWG, not smaller than the circuit conductors (the fixture wires), and not required to be larger than the circuit conductors.
Kyle
Old 09-01-2011, 08:26 AM   #5
I=E/R
a7ecorsair's Avatar
The lamps I've worked with that are suspended by chain have had a two wire rip cord and a separate ground laced through the chain. The box stores should have this.
a7ecorsair is offline   Reply With Quote
Old 09-01-2011, 12:47 PM   #6
Code05's Avatar
Nice call on 250.122 (F), I had not ever even noticed that section. Never had a reason to.
Old 09-01-2011, 01:18 PM   #7
Rewards Points: 560
since the fixture is dark and the chain/lamp cord is also dark, putting a gold colored groundwire around the cord would sure look "hokey". so I used a length of black colored wire (looks like about 26 ga. works fine. tested it to see if it would carry enough current to trip a breaker by actually "shorting" an outlet with it. the breaker "popped" and the wire wasn't damaged. (put an ohm-meter on it to make sure) a licensed electrician can't use a black wire that way but I can!
tnx,
Old 09-01-2011, 01:21 PM   #8
Code05's Avatar
tnx,
Did you read SD515 post about #18 min. Your experiment was worthless and dangerous.
Old 09-01-2011, 06:17 PM   #9
Rewards Points: 560
in my opinion, anyone who's afraid of doing such a test shouldn't be working with electricity (or handing out advice)
tnx,
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 02:57 PM
Question about neutral wire through wall switch guitarmonster Electrical 33 08-08-2010 09:51 PM
EMT and WIRE size - 100 amp sub panel balansaj Electrical 6 05-18-2010 03:17 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 08:13 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
