Wire Size Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 10:04 PM   #1
wire size needed
Got help last night on my power question now i need to know what gauge wire to run,
220 3 phase 90amp breaker, running a 10' section from the panel to my lift.
Thanks in advance!
serrano is offline   Reply With Quote
Old 10-01-2011, 10:09 PM   #2
Electrical Contractor
kbsparky's Avatar
What is the hp rating on the lift?
While one might think a #4 or #3 wire would be required on that 90 Amp breaker, chances are that it may be oversized by 175 or even 250%. The lift may only need a #8 ... hence the info needed from its nameplate ....
-KB
Old 10-01-2011, 10:39 PM   #3
I'll have to check, either way would a 1" flex conduit be ok to use?
Thanks!
Old 10-01-2011, 10:49 PM   #4
kbsparky's Avatar
1" flex would be a real tight fit, if you have to install #3 conductors. Possible, but tight.
-KB
What size wire do I need? walnut777 Electrical 1 12-13-2010 06:41 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 08:15 AM
Advice on current NEC codes to clear up wire size and service issue DIYALLTHETIME Electrical 2 03-05-2009 06:24 AM
Recessed light wire size jizzle Electrical 6 12-03-2008 09:56 AM
Help needed on wire termination Phineas Electrical 4 03-24-2008 10:41 AM
