Old 03-04-2009, 12:11 AM   #1
1.21 jigawatts
macfluke's Avatar
wire size for ac/heating forced air unit
My ac/heating forced air unit(220V) has a 50A breaker with two 8g hot leads and one 12g neutral wire with NO ground wire. I saw on a chart that it needs 6g hot leads, and I was wondering what size the neutral wire needs to be? (the 12g looks small for some reason). also... what size the ground wire needs to be?
macfluke is offline   Reply With Quote
Old 03-04-2009, 01:08 AM   #2
My License Ain't 4 Sale..
If it is 240 V, it doesn't need a neutral. It needs two #6 hots and a #10 ground.
Old 03-04-2009, 01:29 AM   #3
" Euro " electrician
frenchelectrican's Avatar
It must have #6 conductors in there however the major gotcha is if you have standby electric grid heater that can affect the rating if you are under 10 KW you can get by with #6's but if more than that you will need to get proper sized conductors with correct OCPD in there,
Merci,Marc
Grounding Wire Size jamiedolan Electrical 10 01-17-2009 11:53 AM
Wire size for dryer jamiedolan Electrical 14 01-15-2009 06:43 AM
AC unit size? xboxundone HVAC 3 06-05-2008 09:48 PM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
