Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 10:49 AM   #1
Wire size
I want to run power from my home to a garage that I recently built. I have a 200 amp service in the house. I have 110 and 220 outlets in the garage. The only 220 I plan on running is a small air compressor. What size wire under ground should I use to run from the house to the building? I have a separate breaker (60 amp box) in the garage. The distance 125ft from the house to the building?
10agman is offline   Reply With Quote
Old 03-02-2011, 11:12 AM   #2
Rewards Points: 1,452
Use 6 gauge copper wire. For separately run conductors in conduit the ground (4'th wire, required) can be 8 gauge.
The Following User Says Thank You to AllanJ For This Useful Post:
10agman (03-02-2011)
Old 03-02-2011, 02:00 PM   #3
Grounding
Shoud I ground at new box in new garage of back to main box?
Old 03-03-2011, 04:40 AM   #4
Scared Electrician
Saturday Cowboy's Avatar
you will need a ground wire form the house and to drive a ground rod at the garage.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
10agman (03-03-2011)
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 11:54 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
What size wire do I have? 737Pilot Electrical 4 10-09-2008 10:47 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
