Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2010, 09:05 AM   #1
wire size
i need to power a 3/4 hp 220 submersible well pump and a mecury vapor night light 550 ft from the breaker box. what size underground wire should i use?
rac-one is offline   Reply With Quote
Old 05-22-2010, 09:11 AM   #2
What is the amps/watts rating on the pump & the light ?
For a 15a load you are looking at #6 to get the voltage drop down to 8v & ~3%
Old 05-22-2010, 11:16 AM   #3
Larger gauge alum wire might be cheaper than copper.
Old 05-22-2010, 11:28 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
If you can you should wire the MV light for 240v as well. Voltage drop at 240v is dramatically lower than at 120v.
Without the draw of both loads it is impossible to tell you wire size.
Old 05-22-2010, 11:36 AM   #5
MV, 50w to 175w, but the smallest resi CB is 15A?
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 10:54 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
What size wire do I have? 737Pilot Electrical 4 10-09-2008 09:47 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
