Wire Size 60 Amp Sub Panel 145 Feet Away - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2014, 01:20 PM   #1
bandaid1998's Avatar
Rewards Points: 2
Wire Size 60 Amp Sub Panel 145 feet away
New to the forum and I have been reading the posts but didn't find what I am looking for.
My question is this?
I want to add a sub panel to my workshop that is 145 feet away from main panel.
Is this wire size sufficient? 3 # 4 AWG (2 hot & 1 Neutral) 1 # 8 AWG Ground. I want to run THHN in 1 1/4 sch 40 conduit & have ground rod installed.
60 Amp panel based on load of 43A X1.25=53.75A rounded up to 60A
Largest Load
Dust collector 120v start up 22 amps and 14 running amps
Table saw 120v start up 21 amps and 6 running amps (will convert to 240v)
Thanks in Advance for your assistance.
bandaid1998 is offline   Reply With Quote
Old 09-28-2014, 04:30 PM   #2
dmclean701's Avatar
Rewards Points: 152
I assume the conduit is buried. Where it comes out of the ground you might want to use schedule 80 where "it is subject to damage".
dmclean701 is offline   Reply With Quote
The Following User Says Thank You to dmclean701 For This Useful Post:
bandaid1998 (09-30-2014)
Old 09-28-2014, 06:45 PM   #3
Electrician
Rewards Points: 2,828
Largest Load
Sounds good. In theory you could go to #6 hot and neutral on a 60 amp breaker but your idea is even better.
Jump-start is online now   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
sub panel wire size hardgear69 Electrical 5 09-19-2012 12:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Wire size to sub panel zom Electrical 4 06-03-2011 09:46 AM
What size wire for 100 amp sub panel Bean Electrical 7 01-24-2010 07:31 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 05:26 AM
