Wire Size For 240v Shop Tools - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 10:34 AM   #1
Just call me Andrew
Rewards Points: 1,020
Wire size for 240v shop tools
I am wondering what size wire i should run for my 240v outlets in the shop.the tablesaw and bandsaw I am getting both require 240v 15A circuits...should I just run 14/2? Any reason to go up to 12/2?
Is it ok to put multiple 240v outlets on the same circuit? I don't plan to use multiple 240v tools at once.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 02-21-2012, 11:28 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Do you know if your tools will be needing a three or four wire receptacle?
I would use 250v 20a plugs with 12-3 or 12-2 and a 20a breaker
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-21-2012, 11:29 AM   #3
Just call me Andrew
3-wire I believe. (2 hots + g)
Andrew
Old 02-21-2012, 11:38 AM   #4
rrolleston's Avatar
accidental duplicate post
Old 02-21-2012, 11:38 AM   #5
rrolleston's Avatar
If you don't plan on using any two at once one circuit would be fine. And 12-2 or 12-3 depending what your tools need.
Old 02-21-2012, 11:40 AM   #6
Just call me Andrew
I had a bunchof 14/2 lying around I was hoping to use....any reason I can't use it? Req'd circuits are 15a.
Andrew
Old 02-21-2012, 11:41 AM   #7
Rewards Points: 266
What are the actual nameplate amp ratings of the tools? (I'm just wondering if the tablesaw is 15A@230)
Even if a 15 A circuit is all that is required, you may want to go with a 20 A circuit and receptacles because the NEMA 6-20 receptacles seem to be easier to find at big box stores and such. Depending on the amperage rating of the tools, you may be able to run say a dust collector and table saw from one 20 A circuit. Nothing wrong with 15A though. And yes, you can put as many as you want on one circuit.
They also make duplex 240 receptacles or half 120 half 240 but you'll need to go to a supply house for them.
junkcollector is offline   Reply With Quote
Old 02-21-2012, 11:44 AM   #8
rrolleston's Avatar
Could try 14-2 with a 15a breaker and see what happens but sometimes a 15amp shop tool could draw enough when it gets worked hard to trip a 15amp breaker. I would try one outlet really close to the box and see how it goes. Work the tool how you think you will use it and if it works wire it up.
Old 02-21-2012, 11:50 AM   #9
Just call me Andrew
I usually get all my electrical stuff from a supply house. I go enough that they gave me a contractor's account
I don't have either the bandsaw or the tablesaw yet, gettin them in the next 2 weeks.
It lists the minimum circuit size, but what about the max? I'd love to be able to run dust collection on the same circuit, not sure ven a 20A could handle that. Looks like I'll be buying some more 12/2 (or 12/3).
Here's the info from the spec sheets:
Grizzly G1073 Bandsaw:
http://cdn0.grizzly.com/specsheets/g1073_ds.pdf
Electrical:
Minimum Circuit Size.............................................. .............................................. 30 amps at 110V, 15 amps at 220V
Switch............................................ .................................................. ........................... On/Off Toggle with Safety Lock
Switch Voltage........................................... .................................................. ................................................. 110/220V
Cord Length............................................ .................................................. .................................................. ............ 5 ft.
Cord Gauge............................................. .................................................. .................................................. .. 14 gauge
Plug Included.......................................... .................................................. .................................................. ............. No
Motors:
Main
Type.............................................. .................................................. .................. TEFC Capacitor Start Induction
Horsepower........................................ .................................................. .................................................. .... 2 HP
Voltage........................................... .................................................. .................................................. . 110/220V
Prewired.......................................... .................................................. .................................................. ....... 220V
Phase............................................. .................................................. .................................................. ...... Single
Amps.............................................. .................................................. .................................................. ..... 28/14A
Sawstop Cabinet Saw (3hp):
http://www.sawstop.com/products/prof...net-saw/specs/
Motor:
3 hp, 1 phase, 230 V, 13 A
Andrew
Old 02-21-2012, 11:59 AM   #10
rrolleston's Avatar
I would run dust collection on a separate circuit.
Old 02-21-2012, 12:10 PM   #11
Just call me Andrew
The dust collector I am looking at is 120v anyway, just a cheapo 2hp from harbor freight.
Andrew
Old 02-21-2012, 12:23 PM   #12
rrolleston's Avatar
I would try 15 amp circuit and 14-2 or 14-3 wire and see what happens. I would not do any wiring until I knew for sure what they plugs are.
Old 02-21-2012, 12:27 PM   #13
Just call me Andrew
They all use 3-wire, no neutral. just checked. The bandsaw doesnt ship with a plug at all, you wire it yourslef. I'm buying it used, no idea what it has on it. The table saw comes with a 3-wire 15A plug.
So i'd definitely have to change the plug to a 20A, and possibly the bandsaw also.
Andrew
Old 02-21-2012, 12:30 PM   #14
Just call me Andrew
i guess i can run 12/2....on a 15A circuit with 15A plugs. That way if i do trip breakers, I just need to swap the outlets and breakers. If they don't trip, i dont need to do anything else.
Andrew
Old 02-21-2012, 12:40 PM   #15
rrolleston's Avatar
Why would you change the plugs?
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Correct wire size? fatczech Electrical 6 12-18-2011 09:15 PM
What size wire do I need? walnut777 Electrical 1 12-13-2010 07:41 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 09:13 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
