Old 07-13-2008, 07:59 AM   #1
wire size
I am not sure of wire size I need to wire a heater 240 volt 38 amp about 10 ft run. also will a 50 amp breaker work safely?
greywolf6 is offline   Reply With Quote
Old 07-13-2008, 10:43 AM   #2
Licensed Electrician
jrclen's Avatar
wire size
A number 6 wire on a 50 amp breaker will work fine.
John
jrclen is offline   Reply With Quote
Old 07-13-2008, 12:19 PM   #3
nap
You talking to me?
nap's Avatar
wire size
unless this is UF, what is wrong with a #8 ?
Old 07-13-2008, 03:07 PM   #4
Electrician
wire size
A agree and this is why....
If this is fixed electric heat then 424.3(B) applies.... 125% added to the branch circuit... 38 Amps x 125% = 47.5 Amps, looking at 310.16, #8 AWG is good for 50 amps @ 75ºC, as long as its not NM wire, which is restricted to the 60º column at 40 AMPS.
chris75 is offline   Reply With Quote
Old 07-14-2008, 09:36 AM   #5
jrclen's Avatar
wire size
I completely agree with you guys. I knew when I posted that someone would confuse the guy with facts. I am going with the #6 because he is putting in NM. How do I know? I don't. But like I said, the #6 will work just fine with a 50 amp breaker.
John
Old 07-14-2008, 05:10 PM   #6
Electrician
wire size
I just hate people to spend money they dont have to, but you sure make an excellent point, I do admit that.
Old 07-14-2008, 06:56 PM   #7
jrclen's Avatar
wire size
Hopefully the OP will come back and let us know more details. I do agree about the money.
John
Old 07-14-2008, 07:57 PM   #8
nap
You talking to me?
nap's Avatar
wire size
My commercial/industrial mentality made me do it.
Old 07-14-2008, 10:08 PM   #9
jrclen's Avatar
wire size
I can relate to that Nap. I am working very hard to overcome that. I just switched to resi myself. I was just showing off my recent discovery of having to use the 60c column for NM.
John
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire Size Help-400ft line to pond for fountain brownie47854 Electrical 14 04-22-2007 01:50 PM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
