Wire Size 220 /3600 W Toaster - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 09:05 AM   #1
Rewards Points: 150
Wire size 220 /3600 w toaster
Hi moving a 240 outlet from one location, toaster works fine here! but not a convenient area.
"Actualy moving outlet 50 feet from present location"
This will be a 50 foot run, I would like to use armored cable .
This will be a single outlet (One)
Unit is a Panini bread sandwitch toaster 240 60 hz @3600 watts.
I have not looked into the main, I beleive this outlet is a 30 amp
circuit.
I have re wired my whole home from ( knob and tubbing) cir, 1895 and passed inspection so I know white from black and green.
I have very little experance with 240's rules.
1: Can I use 12/2 WG in armored cable on a 50 foot run.
2: Do I have to secure it to a wall ? I would like to string it above a drop ceiling to the wall location bring it down to the outlet using cable straps every 24" 6 foot drop.
deckhand
deck hand is offline   Reply With Quote
Old 04-27-2010, 09:13 AM   #2
Licensed electrician
Rewards Points: 1,876
You would need to verify the circuit size to tell if #12 is large enough. No. 12 is good for 20 amps.
If this is in a commercial establishment it should be installed by a licensed electrician.
Old 04-27-2010, 09:41 AM   #3
Where are you located ?
Residential or Commercial installation ?
Old 04-27-2010, 10:05 AM   #4
Rewards Points: 150
re 220 hook up
We found an electrician to come in and do the job.
deck hand
Old 04-27-2010, 06:11 PM   #5
Electrical Contractor
kbsparky's Avatar
#12 conductor is adequate for a 3600 watt load @240 Volts. 15 Amps.
-KB
Size and type of entrance wire for 200A? Beemer533 Electrical 7 03-15-2010 10:54 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
What size wire do I have? 737Pilot Electrical 4 10-09-2008 09:47 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
