Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 04:16 AM   #1
wire size
I have built a batting cage for my boys. The only problem is its 375ft away from any electricity. I need to power 6 4 lamp T8 32 watt fixtures and a 1/3 HP motor on the pitching machine. I am worried about line loss with using extension cords. Not looking to spend a fortune as I will be putting a desperate electrical service by it when I build a shop in a couple years. Any help is appreciated
slumlord9242 is offline   Reply With Quote
Old 01-25-2014, 08:30 AM   #2
Rewards Points: 874
Are you really a slumlord?????
Mstrlucky74 is offline   Reply With Quote
Old 01-25-2014, 08:36 AM   #3
Master Electrician
Rewards Points: 3,768
For the cost of wire and installation you could purchase a 2500 watt generator.
brric is offline   Reply With Quote
Old 01-25-2014, 08:42 AM   #4
Rewards Points: 874
Thanks you will have fuel cost to consider along with the noise.
Old 01-25-2014, 08:59 AM   #5
No not a slumlord just have rentals and my friends call me one@ mstrlucky74. Could I run 10 gauge thhn stranded wire out through conduit or would the line loss be too much?
Old 01-25-2014, 10:11 PM   #6
Msradell's Avatar
Rewards Points: 128
Why not figure out how much power your shed will need in the future and then run an underground feed of sufficient size for it? You could just have it come up to an outdoor box near the batting cage for now as long as you left enough where to reach the future chat location. It would cost more now but would cost less in the long run.
Msradell is offline   Reply With Quote
Old 01-25-2014, 11:47 PM   #7
Rewards Points: 6,652
Most likely the previous user that used that name with 0024 at the end, just changed the numbers at the end.
Old 01-30-2014, 06:13 PM   #8
24x32= 770w + ~500w @120v = 10A
A 3v drop @10A is 0.3 ohm at 750' is 0.4 ohms/1000' is #6 AWG.
Maybe go with solar, maybe go with dragging charged deep-cycle batteries out there when needed and use an inverter.
Old 01-31-2014, 12:47 PM   #9
Rewards Points: 808
(snip) I need to power 6 4 lamp T8 32 watt fixtures and a 1/3 HP motor on the pitching machine. I am worried about line loss with using extension cords. Not looking to spend a fortune as I will be putting a desperate electrical service by it when I build a shop in a couple years. Any help is appreciated
Remember the 7 Ps. Nobody is looking to spend a fortune on anything. The phrase itself is simply code for "I want a temporary quick fix that costs little or nothing and I will do it right later." I say do it right now. 1" PVC conduit buried 12" with 4 #8s. Put the pitching machine on it's own circuit on a weatherproof subpanel, and the lighting on a 15a circuit. WHEN you build a shed in the future, you cross that bridge when you get to it, like, intercept the existing 1" pvc and reroute it. If you entend to use high loads in this shed (welder, heater(s), power tools, etc) then plan to use larger PVC conduit now, so you can re-pull your larger feeders in the future.
IslandGuy is offline   Reply With Quote
Old 01-31-2014, 01:04 PM   #10
Master Electrician
Burial depth for RNC(PVC) is 18".
Old 01-31-2014, 01:07 PM   #11
Rewards Points: 724
i would run 3#6 alu + gnd in a conduit (you would have 120/240v available) , a lot cheaper than copper 8 or 10 . and you have lots of power available
carmusic is offline   Reply With Quote
Old 01-31-2014, 01:08 PM   #12
Licensed electrician
Rewards Points: 1,272
The #6 AL gives you the same capacity as the #8 copper.
Digitial Timer in 3 Gang box with (2) 3way switches and 1 single pole..confused. BCS Electrical 33 03-21-2016 12:30 AM
New Sub Panel Wire Size? johnsas Electrical 4 08-29-2012 12:20 PM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 10:38 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
