Old 05-20-2011, 11:41 PM   #1
Question
wire size for 160' feeder to subpanel
I am planning on running a subpanel to my shed the total length of the run will be 160' by reading all of the other threads i am assuming i will need a ground rod connected to the ground box on the sub panel.
but what type and size wire would i need to run from the house main panel. I would like a minimum of 30a 220v and max of 60a220v no real reason for 220 other than if im running the wires well why not.
so what size/type wire is recommended both for the feeder and the ground and what size ground rod would i need please specify for 30/40/60.
Thanks in advance,
Steve
i am not trying to be demanding just trying to be straight forward with what i am asking.
steveski is offline   Reply With Quote
Old 05-20-2011, 11:42 PM   #2
by the way i will be pulling permits and doing everything to spec. I just want to determine wire size/cost before i submit any plans
Old 05-21-2011, 09:31 AM   #3
I=E/R
a7ecorsair's Avatar
There is a reason...
You will have more power available with smaller wiring.
a7ecorsair is offline   Reply With Quote
Old 05-21-2011, 10:41 AM   #4
run three #2 xhhw aluminum,and one #4 xhhw.the #2's are hots and neutral and #4 is ground.
oleguy74 is offline   Reply With Quote
Tags
subpanel wire longrun
What size wire to use running underground ms66cadillac Electrical 21 01-13-2011 12:14 PM
What size wire do I need? walnut777 Electrical 1 12-13-2010 07:41 PM
Size of Wire & type of wire agman Electrical 6 11-10-2009 09:13 PM
wire size for ac/heating forced air unit macfluke Electrical 2 03-04-2009 01:29 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
