Old 06-14-2008, 05:38 AM   #16
Wire size 10ga 8ga or something else
Originally Posted by hd82 View Post
I am putting in a new well with 1hp pump that draws between 7.5 and 12 amps @ 220volts. I need to pull about 400' of wire underground in pvc conduit from breaker box in barn, using 20amp 2 pole breaker Should I use 10/2 with grnd, 8/2 with grnd solid romex or something else?
I think I have found the solution to my problem. I called the power company to add a service and this is what I got from them;
"No problem adding a service for your pump and shed (I told them I needed service to my utility shed by my pond) we can run overhead, poles and meter for $1.75 per ft, underground is much more. All you need is a finshed shed, wired for service, a breaker panel, permit for service and inspection." I wanted to put a shed anyway so the grandkids can have a place to put their fishing stuff, fish food and corn for the deer. It will be a big pumphouse.
To be honest I can't buy the THWN, conduit and misc stuff for that!
I want to thank all who gave me positive advice as I now know more than when I asked my question, those of you who thought negative feedback without support was the why to help, I heard you the first time, "This AIN"T my first RODEO!", and I promise it wont be my last.
Thaks again, hd82
hd82 is offline   Reply With Quote
Wire size and breaker discrepancy Randell Tarin Electrical 22 04-10-2008 08:03 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
Wire size for distance Question fburke Electrical 4 07-28-2007 10:29 AM
Wire size for Central Air mwtuck HVAC 2 12-01-2006 06:06 PM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 08:43 PM
