Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 05:03 PM   #1
Question
Wire size
What size wire do I need from the breaker to a 240VAC, 1.5hp deep well pump?
esmith is offline   Reply With Quote
Old 06-13-2011, 05:27 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
#14 with a 25A breaker.
However, because of distance from the building (you didn't specify) I would probably run #10.
#14 is good for 20A
#12 is good for 25A
#10 is good for 35A
electures is offline   Reply With Quote
Old 06-13-2011, 07:19 PM   #3
Missouri Bound's Avatar
electures.....your wire to ampacity rating is incorrect.
10 is for 30 amp
12 is for 20 amp
14 is for 15 amp.
Old 06-13-2011, 07:38 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
10 is for 30 amp
12 is for 20 amp
14 is for 15 amp.
Motors do not have to follow this basic rule found in 240.4(D).
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (06-13-2011)
Old 06-13-2011, 07:55 PM   #5
electures's Avatar
Old 06-13-2011, 08:01 PM   #6
Electrical Contractor
It's like birds chirping in the morning.
hpp58 is offline   Reply With Quote
The Following User Says Thank You to hpp58 For This Useful Post:
Speedy Petey (06-13-2011)
Old 06-14-2011, 12:15 AM   #7
" Euro " electrician
frenchelectrican's Avatar
The distance may affect the conductor sizing so if you post the distance not only from the house where the pressure tank controller is located but from there to the well itself that is first part then second part is the well depth itself that how I add up the distance so you can able use the proper sized conductor.
Merci,
Marc
Old 06-14-2011, 12:24 AM   #8
Rewards Points: 512
Originally Posted by electures View Post
People try to be helpful (and learn) here. There's no need for sarcasm. Missouri was politely corrected, and it should end that way.
Old 06-14-2011, 06:47 AM   #9
electures's Avatar
I didn't know that that modicon meant sarcasism. I used it because I agreed with Speedy Petey. Sorry if I offended anyone. Maybe the modicans should be listed and labeled.
The Following User Says Thank You to electures For This Useful Post:
sirsparksalot (06-15-2011)
Old 06-14-2011, 03:08 PM   #10
For the record.....I'm not offended and thanks for the heads up on the code reference. I unfortunately am not correct 100% of the time.
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
electures (06-14-2011), sirsparksalot (06-15-2011)
Old 06-14-2011, 04:45 PM   #11
electures's Avatar
Yeh I know how you feel. I thought I was wrong once, but I was mistaken.. (Sound fimiliar Petey?)
Old 06-14-2011, 06:20 PM   #12
I'm hardly ever wrong, except when I am not.
Old 06-15-2011, 01:39 AM   #13
Rewards Points: 512
I'm always reading shat that doesn't exist into posts. It's part of my persecutory delusions. I apologize.
The Following User Says Thank You to sirsparksalot For This Useful Post:
electures (06-15-2011)
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
wire size for 160' feeder to subpanel steveski Electrical 3 05-21-2011 09:41 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
