Wire Size For 100 Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 08:27 PM   #1
Wire size for 100 service panel
I'm replacing an old existing 60amp service panel to 100amp, my question is what size wire to I need from the meter to the weather head so poco can hook up my service.
Had the meter location spotted already, permits have been pulled.
Also, is 1-1/2 rmc ok to use for the mast?
Serrano7503 is offline   Reply With Quote
Old 07-14-2013, 08:31 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
#2 Al or #4 copper
Edit: yes 1 1/2" is fine.
wirenut1110 is offline   Reply With Quote
Old 07-14-2013, 08:32 PM   #3
Rewards Points: 150
#4 copper or #2 al for residential. The poco may want a larger mast ours requires a 2 inch minimum so check with them
RIP EJT
usair is offline   Reply With Quote
Old 07-14-2013, 08:33 PM   #4
#4 for all 3 wires? what about the mast size?
Old 07-14-2013, 08:34 PM   #5
Thanks!
Old 07-14-2013, 08:35 PM   #6
One last thing.....I wrap the neutral in white tape to identify it, correct?
Old 07-14-2013, 08:39 PM   #7
Rewards Points: 150
yes
RIP EJT
Old 07-15-2013, 12:35 AM   #8
" Euro " electrician
frenchelectrican's Avatar
#2 Al or #4 or #3 CU will work fine.
However check with your POCO on 1.5 inch rmc for mast and I am pretty sure you may end up backguyed that one and most case I normally go with 2 inches RMC that will take care of most common resdential drops ( up about 100 feet or so ) but any longer than that will be backguyed.
When you do the backguyed set up make sure you hit the sturcure wood not just a sheeting of roof at all. need to hit 2X4 rafter or simiair like that.
Merci,
Marc
Wire Size to Sub Panel George6488 Electrical 1 12-01-2012 10:20 PM
changing to 200 amp service mbaldwin Electrical 3 03-29-2012 09:00 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
wire size for sub panel DSimo Electrical 1 07-31-2008 07:26 AM
