-   -   Wire size for 100 service panel (http://www.diychatroom.com/f18/wire-size-100-service-panel-183632/)
Serrano7503 07-14-2013 07:27 PM
I'm replacing an old existing 60amp service panel to 100amp, my question is what size wire to I need from the meter to the weather head so poco can hook up my service.
Had the meter location spotted already, permits have been pulled.
Also, is 1-1/2 rmc ok to use for the mast?
wirenut1110 07-14-2013 07:31 PM
#2 Al or #4 copper
Edit: yes 1 1/2" is fine.
usair 07-14-2013 07:32 PM
#4 copper or #2 al for residential. The poco may want a larger mast ours requires a 2 inch minimum so check with them
Serrano7503 07-14-2013 07:33 PM
#4 for all 3 wires? what about the mast size?
Serrano7503 07-14-2013 07:34 PM
Thanks!
Serrano7503 07-14-2013 07:35 PM
One last thing.....I wrap the neutral in white tape to identify it, correct?
usair 07-14-2013 07:39 PM
yes:thumbsup:
frenchelectrican 07-14-2013 11:35 PM
#2 Al or #4 or #3 CU will work fine.
However check with your POCO on 1.5 inch rmc for mast and I am pretty sure you may end up backguyed that one and most case I normally go with 2 inches RMC that will take care of most common resdential drops ( up about 100 feet or so ) but any longer than that will be backguyed.
When you do the backguyed set up make sure you hit the sturcure wood not just a sheeting of roof at all. need to hit 2X4 rafter or simiair like that.
Merci,
Marc
