Is The Wire Short Enough On This Electrical Socket? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 05:11 PM   #1
Is the wire short enough on this electrical socket?
Good evening, I'm completely new to home repairs, so I'd like to make sure I don't burn down my condo: Is the wire short enough on this electrical socket? Does it matter since it's neutral?
Thank you.
Is the wire short enough on this electrical socket?-100_3487.jpg   Is the wire short enough on this electrical socket?-100_3491.jpg
W_Mitty is offline   Reply With Quote
Old 05-27-2011, 05:16 PM   #2
Licensed electrician
Rewards Points: 1,478
There is a strip guide on the back of the receptacle.
I would not cut any length off the conductor. You should have at least 3" past the open face of the box.
The loops go around the screws clockwise. Yours are counterclockwise.
W_Mitty (05-27-2011)
Old 05-27-2011, 05:32 PM   #3
Sorry for the, I assume, simple questions, but I want to get it right.
I assume the receptacle is the plug: am I correct?
Is the conductor the white protective covering or the copper? I assume the copper, as copper conducts electricity. There should be at least 3" inches of covered wire from the box, correct?
Does this rule go for grounding wires too? I just replaced ten light switches, and I didn't pay attention to which way the grounding went.
I'm going to change the position of the wire, but out curiosity, why does the wire need to go in a certain direction?
Thank you for the prompt response.
Old 05-27-2011, 05:44 PM   #4
Another Question:
If I were to stick the wires in the back of the plug, is a tiny sliver of copper okay on the outside? I tried it with another plug, but due to extra wire in the box, the wire bends as I push it back into the box; the bend creates the sliver.
Old 05-27-2011, 05:47 PM   #5
The receptacle is the part you are attaching to.
The conductor is the wire. It is sometimes covered in insulation. The insulation gets stripped off when making the connections. You have three, black, white, and bare.
With a clockwise loop it will pull tighter when the screw is tightened. CCW will loosen. Loose connections create heat. Heat creates fire etc.
Old 05-27-2011, 06:23 PM   #6
Since this is the case, is it correct to assume the direction for the grounding doesn't matter?
And thank you very much, Jim.
Old 05-27-2011, 07:06 PM   #7
Rewards Points: 330
ground connects clockwise just like hot and neutral wires.the ground is protection.to trip breaker in case of a hot wire shorting to ground.
oleguy74 is offline   Reply With Quote
The Following User Says Thank You to oleguy74 For This Useful Post:
W_Mitty (05-28-2011)
Old 05-27-2011, 09:01 PM   #8
Yes, all the wires should be CW.
You can preform the wires into a sideways Z to help them fold into the box. As long as you strip as shown in your first pic you should be fine.
Old 05-27-2011, 10:11 PM   #9
Rewards Points: 506
Is a sideways Z the same as an N? Sorry...couldn't resist.
jlmran is offline   Reply With Quote
Old 05-28-2011, 05:14 AM   #10
Absolutely not, funny guy. Can't you see the sideways Z is more compressible than the N?
Tags
electrical socket
Electrical Short - No Power Now Diggyj Electrical 8 01-03-2011 09:59 PM
Electrical Socket Help! SMBbone Electrical 4 01-26-2010 10:52 AM
Electrical socket question hayzen Electrical 2 01-15-2010 02:16 PM
Cap electrical wire? oscarMadison Electrical 5 03-01-2009 09:26 PM
Standard gauge for household electrical wire tripower Electrical 2 09-21-2008 11:42 PM
