Wire Shop Outlets. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 08:54 PM   #1
wire shop outlets.
Hi,
I'm wiring a detached shop and I need to run wires along the wall to the outlets. The walls of this building are 2x4s on 16" centers. They then have 2x4 nailers on 2' centers up the wall and then the metal siding. Is there any reason I can't run the wire on top of the nailer in the 2" gap between the wall and the metal siding? Certainly would save me having to drill a bunch of holes...
Thanks,
Dave
tgidave is offline   Reply With Quote
Old 07-23-2010, 01:04 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by tgidave View Post
Hi,
Thanks,
Dave
Do not use the nailer board as you describing due the 1.5 inches clearance and some case someone will run a big screw and cut the conductor in cable or conduit format.
Are you plan to close up the wall after all the rough in is done or leave it open ??
For myself if open wall I rather run in MC cable or in conduit eitherway it work good.
{ I like the conduit the best due you can able change the circuit or arrangement without tearing the wall apart if all close up }
Merci.
Marc
Old 07-23-2010, 01:46 PM   #3
Actually the walls will be insulated and covered with OSB. Since the outside walls are metal I don't imagine anyone will be putting nails or screws into it...
Dave
Old 07-23-2010, 02:40 PM   #4
Electrician
Proby's Avatar
It's perfectly fine to run the wires there.
Altho drilling wooden studs isn't a big deal. After you lay out the boxes you can run thru a garage with a drill in 15 minutes.
Be honest! You like conduit best because it gives you more work and you make more money!!
Proby is offline   Reply With Quote
Old 07-24-2010, 02:02 AM   #5
Yeah and not only that it did make more money but make the place look heckva alot nicer and my shop I allready ran conduit allover the place { yeah the reason why I have to do do that due it a commercal building on my lot and it allready wired with 480Y277 system in there}
Merci.
Marc
Old 07-26-2010, 08:03 AM   #6
Well, it's done... We'll see what the inspector says. I routed the wire so it will be fairly easy to change if the inspector has a problem with it.
Thanks, all, for the input.
Dave
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
