Wire To Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 11:02 AM   #1
Wire to Shed
First, I would like to say thank you in advance for advice and direction.
I currently have a storage shed located 30' from the house which does not have power running to it. My initial plan was to run install an additional breaker then route the wire through my attic and through the rear exterior wall. Unfortunately our driveway is poured such that it meets the foundation beneath the breaker panel. This prevents me from taking an entirely external route with the wire.
What is the best way to route the wire through an exterior wall; down through the wall, or through the soffit and attach conduit to the brick?
bbradl12 is offline   Reply With Quote
Old 05-19-2012, 12:13 PM   #2
Rewards Points: 58
If you are running only one cable and your panel is on the wall you want to penetrate, why not drill a hole through the panel to the outside. Then install a weather tight box or LB and run conduit from there all the way to the shed?
Use the search function of this site for lots of information regarding this very subject.
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 02:42 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 11:44 AM
