Old 09-10-2012, 09:17 AM   #1
Wire Recommendation - Outdoor
I need to run an underground wire to a single GFCI outlet through my back yard. The length of wire from the breaker to the outlet is 100'. I need a recommendation of the type wire I should use (UF vs. UF-B) (12/2 vs. 10/2). I will be purchasing from either Lowes or Home Depot.
The outlet will only be used to run small hand tools, radio, etc.
meppwc is offline   Reply With Quote
Old 09-10-2012, 10:00 AM   #2
Electrical Contractor
UF cable or run pipe and thwn wires.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
ground wire for outdoor fixture kingdomfirst1 Electrical 1 02-11-2012 07:24 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
wire for underground/ outdoor mharwell01 Electrical 4 09-13-2009 02:50 PM
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 12:46 PM
Indoor wire vs outdoor wire Potomac101 Electrical 2 12-31-2007 04:00 PM
